Results 1 to 10 of 25
Thread: [Work In Progress] T-rex skull
10-16-2014, 11:50 PM #19
Thanks Serena,
I printed the rod by positioning it horizontally on the bed with a 0.2 layer height: round side bottom.
If you can get your bed to stick enough then it should be fine. If the print comes lose during the print then either make the bed stick more, or turn down the print speed (to prevent it from tubmling over).
But I think you could also print it vertically; just takes a bit longer and will create a tiny bit of cleanup for the second 'bulge'.
Good luck!
