Results 1 to 10 of 232
10-08-2014, 08:46 PM #11
- Jul 2014
- Eastern Colorado
- 536
I got it working to the point where I can access the web page on my phone's browser without using wifi. Current problems are, 1, the webcam I have doesn't seem to work with mjpeg-whatever, and 2, if I upload a .gcode file to the raspi, it tries to send commands even while old commands are still being executed. I have auto bed leveling set up and running, and while it's probing the bed, nearly 60 commands get sent to the printer, which then chokes because it last saw command #13. So for now I'm stuck with uploading .gcodes to the SD card, and printing from there.
Did either of you guys need to use a powered USB hub to get your webcams working, or did they work plugged directly into the raspi?
Edit: I fixed problem 2 by increasing the communication timeout to 300. Now OctoPrint doesn't get carried away sending commands to the printer without a response.Last edited by AbuMaia; 10-08-2014 at 09:58 PM.
