Results 11 to 14 of 14
10-03-2014, 12:34 PM #11
I'll probably get started with the Industrial blend from these guys:
http://www.funtodo.net/our-3d-resin-properties.html
or this one from Makerjuice:
http://cadprint.ch/index.php/en/onli...g-1l-28-detail
But there are new ones every few months on the market,
I might try to add some carbon micro fibers to see if it helps....
10-03-2014, 01:16 PM #12
10-03-2014, 01:21 PM #13
12-12-2014, 11:03 PM #14
- Dec 2014
96 microns is not the layer height, that is the X/Y resolution. As in the smallest feature possible and in this case the pixel density of the screen itself. This is actually pretty good compared to most other SLA printers that are laser based (lowest claimed x/y resolution being 150 microns, Form1+ is at 300 microns for example). Sure it doesn't beat DLP's at its best, but given the build area with 96 microns x/y res, its a winner.
