![Quote](images/tf_ideal/misc/quote_icon.png)
Originally Posted by
bford903
Being a jeweler and having experience with multiple printers, I'll tell you what I've found.
*Modern extrusion printers (ABS, PLA, etc.) - Not for jewelry use. Very low resolution (for jewelry). Not castable. For larger objects.
*Projet 1200 by 3D Systems - This is the printer I use. DLP, High resolution prints, fast build time (sub 2hrs), built-in UV curing chamber, however this printer uses only one kind of material and is only castable if you're set up for platinum casting. Platinum casting is expensive. I make rubber molds from the prints and cast in wax.
*B9 Creator/Form 1 - This is the printer I want. DLP, High resolution prints suitable for jewelry, can use different types of resin, cannot comment on castability but heard good things. Contacted multiple people on the B9 Creator forums requesting a sample print and received many replies but haven't received any prints to date. I put the B9 and the Form 1 together because they are both DLP printers that can use different types of resin. I think the B9 is more customizable than the Form 1 however.
*Metal Printers - Just put them out of your head for the time being. Very bad surface quality. You'll spend days cleaning it up and will be disappointed at all the detail lost.
*Solidscape - This printer is the standard for the jewelry industry IMO. This printer has the resolution and the castability required by the jewelry industry. But the cost is significant. 50K or higher. This machine will also make you tear your hair out. The machines are notoriously finicky, requires constant maintenance, replacement parts are crazy expensive, print times are slow, and the material is extremely brittle. But the quality and castability are there.
PMC does shrink. It shrinks by about 50%. Very significant. Usable for only certain projects like Davo said. Would like to see a PMC Printer though. Is there such a thing?
As far as printing services go, Shapeways has been very good to me. Wide array of materials including a castable wax (from the Projet 3500 CPX) I've tested myself. Prices show up instantly after uploading the CAD file. I like the ease of use. Sent in a signet ring and it cost me $27 to have it printed in castable wax. My friend with a Solidscape would charge me $50! 3D Systems has a similar program called "Quickparts" however be prepared to spend a lot of time on the phone. They don't reply to emails so you have to call and be pushy. This is what the head of Quickparts at 3D Systems told me when I met him recently. Call and be pushy. Cannot comment on the cost. Shapeways replied the same day I sent in my CAD file; 3D Systems took almost two weeks to get back to me so I went with Shapeways. I like not having to worry about it.
Hope this helps.
