View Poll Results: So... Silica Aerogel Infused 3D Printer Filament. Good Idea/Bad Idea?
- Voters
- 8. You may not vote on this poll
When Will It Ship?
1 12.50% -
Interesting... What are the Specs?
7 87.50% -
Sounds neat. Good Luck
0 0% -
Meh.
0 0% -
Dude, rethink it.
0 0%
Results 11 to 11 of 11
09-29-2014, 08:07 AM #11
I too would like to know some of the physical strengths of the material. I do a lot of RC sailboat racing, and designing a hull that the material is lighter and perhaps stronger than normal material would be a plus. Especially if it's buoyant. Most Open design classes have a minimum weight limit, so if I could reduce the amount of mass in the upper hull, moving the difference to the ballast in the keel, that would add a few degrees of pointing and speed to the boat.
Resin has changed after...
