Results 1 to 10 of 10
Thread: weirdness in the infill
09-13-2014, 09:36 AM #1
So I stopped a mould print mid print as i needed to print something else
Also figured it's useful to have something showing infill, to explain it to people.
The print was set for 10% infill.
And then I saw this:
Can anyone explain what the splodge of plastic is doing in the midst of the infill ?
This was a simple openscad design. With a stretched sphere removed from a cube.
I've never stopped a print midflow before, so is this kind of random plastic splodge normal ?
It's different both sides as well, which is even weirder.
It was sliced and printed from makerware.
09-13-2014, 10:04 AM #2
- new jersey
- 752
I cant tell by the puc. If you preview the gcode does it show up?
09-13-2014, 11:03 AM #3
don't know - is that the same as print preview in makerware ?
I'll have a look...
No, preview just has honeycomb pattern.
I'll try previews different settings.
Okay, that's weird. It looks like it's some kind of hidden extra infill. You don't get it at 30% percent but you do at 10-15-20-25.
Maybe it's there to support the cavity. As the honeycomb infill gets thicker the other stuff gets smaller.
Huh - just goes to show, you never really know what's inside things :-)Last edited by curious aardvark; 09-13-2014 at 11:15 AM.
09-13-2014, 04:44 PM #4
- new jersey
- 752
yeah man i dont know since i have never used makerware. i use simplify 3d and it has a real nice gcode preview where you can exactly what is going to happen when you print.
09-13-2014, 07:09 PM #5
09-14-2014, 01:06 PM #6
nope never used netfabb.
The outsides of everything are always what i want them to be - never looked inside before :-)
09-14-2014, 09:46 PM #7
- new jersey
- 752
usually when something prints very strange like that it ends up being errors in the model like geoff said. download netfabb basic or you can use their cloud service. either way it will tell you whats wrong and correct it.
09-19-2014, 02:08 PM #8
I don't actually care enough to spend time running perfectly useable models through yet another piece of software - was just curious what caused it :-)
So thanks for the info :-)
I also find that models print quite a bit faster than makerware tells me they will. Which as it sliced it and knows exactly how fast everything is going to go, seems weird.
Would that be something to do with the print acceleration thing in the firmware ?
09-21-2014, 01:25 PM #9
- 349
09-24-2014, 06:15 AM #10
well not easily.
For one you have to look down on it. And for another I geenrally don't stand there watching a print till it's done :-)
