Results 1 to 10 of 23
11-26-2013, 11:15 AM #2
- Nov 2013
- 8
1 thing comes to mind for me, because i had this problem. but first
I think your printing with ABS looking at the temperatures you're using.
Your bed temperature is probably good for small objects, the problem with larger objects is, that when the bed temperature is so high and your objects that are tall will have a much faster cooldown, this can create warp withing the object so when you have this problem you will know why.
As far as i know the best layer height is half your nozzle diameter which would be 0.2 for a nozzle of 0.4.
But most settings are generally accepted , there is always a variation for everybody, because lining at a different location gives different parameters to think about.
