09-23-2014, 06:47 AM #1
- Jul 2014
- 14
Flashforge Creator X reboots/resets when trying to set temp for printbed
So....my new issue
I just fixed the issue where my machine would not turn on. The wiring from the power supply to the circuit board was melted...replaced these parts and now the machine turns on....wooty!
But...now i ran into another issue.
Any time I try and preheat/heat the build plate platform...the machine resets/reboots. Any ideas? Thermostat bad or build plate bad?
(this thing just gives me one problem after another in the last month:
1.) first it was the extruder would not move in the x-axis without grinding....fixed that
2.) Next machine would not power on...fixed that
3.) Now the build plate won't heat up without restarting machine)...UGHHHHHH!
Time to move onto an ultimaker pro I think
-Anthony
09-23-2014, 08:06 AM #2
- Burnley, UK
- 1,662
My guess would be build plate bad and that is what you melted your wires with. Check the resistance of it and the current flow to it if you can.
