Originally Posted by
DarkAlchemist
Well, here is something I have been wondering about for a while now but what is the purpose behind raising and lowering the arm between each probing? I see absolutely no reason for it and on a delta printer it doesn't do that. Makes very little sense to me to keep raising and lowering the arm/switch between probings when you can just lower the arm (before probing the first point), keep everything else the same, and after the last point is measured raise the arm.
