![Quote](images/tf_ideal/misc/quote_icon.png)
Originally Posted by
JamesCooper
harpo, thanks for the details. We've had great success using hot glue to mount many of the pieces. In last night's update you should be able to see the test rig we are using now, which is made from plywood and hot glue. The only real requirement is that it's sturdy so that it doesn't move during the print. A clamp would work, as long as you don't apply too much pressure and crack the plastic.
