09-05-2014, 04:44 AM #1
- Sep 2014
Improvement of a surface on a supported print
Hi,
Firstly, hello thisis my first post
I have a Replicator2 running sailfish through Makerbot. It has an upgraded nozzle so it can printflexible filaments and I print on a glass build plate with Fructis extreme hold(nothing beats it!
So the problem Ihave is that I'm trying to print a part for a project I'm working on but thesurface on the underside is real badbecause of the support structure I think - or maybe it's to do with the first layer which sits on top of the support structure I'm not sure.
Is there a settingin the slicer profile I could amend that wouldfix it??
Here's a couple ofpics of both sides of the piece, thanks
09-09-2014, 08:17 AM #2
- Sep 2014
no help on this
09-09-2014, 03:54 PM #3
- Oakland, CA
- 935
The real solution would be using a second extruder to lay down soluble support structures, so that you wouldn't have to choose between bad filling due to unsupported filament or having to recarve the undersurfaces of your parts. High-end FDM printers do that, but none of the cheap ones seem to have implemented it yet.
Andrew WerbyLast edited by Geoff; 09-09-2014 at 11:02 PM.
09-09-2014, 11:03 PM #4
