Thread: One up Vs. Two Up
11-20-2013, 08:16 AM #1
One up Vs. Two Up
Can someone explain to me what the major differences between the One Up and Two Up are?
11-20-2013, 09:43 AM #2
- Nov 2013
11-21-2013, 01:50 PM #3
- Nov 2013
- Northeastern University, Boston MA
There are also I believe 2 frame pieces that are physically longer. But the good news is that if you buy the one-up, there will soon be an upgrade kit to turn your one-up into a two-up for somewhere around $80. If you don't think you'll need the bigger build area, go with the one-up. If you find you could use the extra space, just upgrade when the kit becomes available!
*Note that if you buy the heated bed for the one-up, it would not be compatible if you upgrade using the two-up kit. I would advise on holding off on the heated bed if you were thinking about it until you are sure which size you want.*
Printing time- Is this right?
