Results 41 to 50 of 189
Thread: Show your MODS
08-23-2014, 08:51 PM #41
- Jul 2014
- Eastern Colorado
- 536
08-24-2014, 12:28 PM #42
I have been using adhesive backed LED strips to light up my print bed on my Makerfarm Prusa i3v 8" printer but the adhesive failed and the strips fell into my print.
I wanted to design a clip on, light weight tray to glue the LED strips down firmly, without having to glue them directly to my carriage frame.
Behold, the finished product!
Installation is easy, all you do is loosen one screw on your x carriage, press the screw slot of the tray mount on to the screw shaft and tighten the screw. Repeat on the other side and your done!
http://www.thingiverse.com/thing:438960Last edited by gmay3; 09-02-2014 at 08:39 AM.
08-27-2014, 11:10 AM #43
- Dearborn, MI
- 23
I have the 10" i3v kit. All of my motors get hot when printing PLA or ABS. All of the motors are also at the recommended voltage. I turned the voltage down on the extruder motor from 0.39 volts to about 0.32 and it still gets hot, hot enough to soften and warp the extruder block after about an hour. I now have fans on all the motors except the Z-axis ones. The fans helped a lot, I can actually touch the motors now without pain in my fingers throughout full prints. With all settings relatively the same, seems like some people have hot motors and some dont.....not sure why.
08-31-2014, 08:30 AM #44
Hot End Mounted RGB Programmable LED Ring
I, like other people on this forum, really wanted my prints to be illuminated while the printer was operating. I first thought about going the adhesive-backed LED strip route, but thought that they would eventually unstick, which was exactly what happened to gmay3. I bought a cheap Adafruit LED ring that has individual drivers for each LED and its own custom library for programming the properties of each individual LED through the Arduino IDE. It fit perfectly around the J-Head, not at all tight. It might even work on your bulkier hot ends. I ran the power, ground, and data input wires to the back with the rest of the extruder block wires where I then connected it to a perfboard that had an Adafruit 5V Trinket (basically a mini Arduino that costs less than half the price of an Arduino-Mini, just with less pins). I also connected it to a latched switch that had an integrated LED ring so it looks nice and pretty. You can find the link with some pictures and a schematic below. As of 8-31-2014, there aren't any pictures of the actual LED ring in action, just some pictures of the components and assembly. I'll be adding a picture when I return home.
http://www.shawftware.net/2014/08/pr...d-mounted-led/
09-03-2014, 02:22 PM #45
- Jul 2014
- Ontario, Canada
- 257
Not really a mod, but finally got the i3v 10" calibrated last night. Here's a little shot of the new printer along side it's little brother. Mods include my z-endstop mod, and flanged idlers.
09-03-2014, 02:39 PM #46
09-24-2014, 09:38 AM #47
- Jul 2014
- Ontario, Canada
- 257
Just wanted to throw this out, that anyone looking for the Z end stop mount on Thingiverse, it has been removed. I have removed my files from Thingiverse and switched to YouMagine.com. You can download my new z bracket and new cooling fan from here: https://www.youmagine.com/users/minimadryan
Cheers
Ryan
10-10-2014, 01:21 AM #48
- Jul 2014
- Eastern Colorado
- 536
Also not really a mod, but perhaps a helpful idea for others. I got a pack of "Super Sticky" Post-its, and have mounted a pad to my power supply for an easily-accessible source of paper for whatever need, including Z-axis calibration.
10-10-2014, 09:31 AM #49
You guys are posting some great stuff here. This thread is working out exactly as I hoped it would. Keep it coming.
I'm jealous of you guys with the new rail version of the printer. I need to go ahead and upgrade mine. I'm getting beautiful prints with my rod version these days but I do love the look of the new one. Keep modding....Bambu P1S/AMS
10-13-2014, 04:52 PM #50
- 134
