  1. #1
    Methods of continuing a print when spool of filament runs out?
    What do you guys do when you are in the middle of a print and the filament spool runs out? Is there a way to generally keep the print going with a new spool, or is the print basically ruined? I've had this happen to me several times and have been extremely pissed off each time. Is there some sort of device I can use to connect the tales of the filament? What do you guys normally do?
  2. #2
    Technician
    Jun 2014
    Location
    3D Printer Tellus
    Quote Originally Posted by RepRapOwner View Post
    I think you should buy Pedros Fuse. It is still a project that is in the Kickstarter project, however it is 100% funded and he will release the machine very soon. I think it will cost around 60 USD.
  3. #3
    I just pause the print, switch out the filament, then resume the print.
    repetier software
    bukobot printer
  4. #4
    depend on your printer. there should be a "change filament" during printing. it will automatically continue where it left.
    dont let the filament to run out completely.
