Results 191 to 200 of 757
08-19-2014, 04:38 PM #191
- Aug 2014
- 627
It now works,
echo:Home X/Y before Z
I then homed X and Y then Z worked perfectly.
Just did a G28 then hit the home Z and it too worked perfectly.
I did notice that the G29 code in the file is missing the enhanced code so I take it we are starting from scratch?Last edited by DarkAlchemist; 08-19-2014 at 04:57 PM.
08-19-2014, 05:11 PM #192
08-19-2014, 05:37 PM #193
- Aug 2014
- 627
Marlin_main.cpp:1530:30: error: ‘AUTO_BED_LEVELING_GRID_POINTS’ was not declared in this scope
if (n_points<2 || n_points>AUTO_BED_LEVELING_GRID_POINTS ) {
In the Configuration.h you have above the AUTO_BED_LEVELING_GRID has been commented out.
It now compiles fine and is uploaded to the Arduino.Last edited by DarkAlchemist; 08-19-2014 at 07:01 PM.
08-19-2014, 06:59 PM #194
08-19-2014, 07:05 PM #195
You already fixed the mistake... But there is one more change in that new Configuration.h file. It has AUTO_BED_LEVELING_GRID_POINTS at 4. That will let you do 2x2, 3x3 or 4x4 for the grid.
08-19-2014, 07:22 PM #196
- Aug 2014
- 627
Switching that back to 2 again until everything works right.
08-19-2014, 11:32 PM #197
I understand why you say that.... But Guess what??? If things are not working right, it will be useful to ask for a Bed Topology report with lots of grid points. What ever that number is, it defaults to 3x3 but it can only go as high as the #define for AUTO_BED_LEVELING_GRID_POINTS says. 2x2 is OK. We can change it later if we need it.
What's the nozzle doing?
Can you print?
08-20-2014, 12:47 AM #198
- Aug 2014
- 8
08-20-2014, 09:42 AM #199
08-20-2014, 10:22 AM #200
- Aug 2014
- 627
