Originally Posted by Mjolinor Sailfish does not understand Gcode. You can convert and send together with GPX if you can get it to work correctly, I failed on that front. Yeah true; but what interface would I use to send the (converted) commands to the printer? PuTTY or something similar maybe? Is this even possible?
Forum Rules
