Results 41 to 50 of 64
08-08-2014, 09:48 AM #41
This is the opposite of what I always thought was true. I've been having trouble with bridges lately. I'm messing with speed settings this morning using that ThingiVerse file you posted.
UPDATE: For my printer, high speed bridging fails horribly. I'm going to keep playing with it, but Bridge Speeds of 20mm/s with a filament rate of .9 works on all the different size bridges. The biggest flaw is the gap in the center of some of the bridges. That almost looks like a Slicer issue???
0808141014-00.jpgLast edited by Roxy; 08-08-2014 at 10:19 AM.
08-08-2014, 11:40 AM #42
It's intersecting how different the settings need to be for various slicers. Well, maybe more frustrating than interesting. Your bridge looks pretty good from the top (except for the gap). So that was at a slow speed? I just calculated my speed (200% of my default speed) and it was 35. Slower than that and I had major issues. My test at a speed of 21mm/s completely failed and 'no' bridges were connected.
I've attached my data. Four of my first tests are not there as I didn't think to make the chart until after I realized I was having trouble. I rearranged the rows from worst to best. Just found out you can paste tables from Excel and they remain intact. Nice...
Simplify3D Bridge Tests Other/Bridging Layer Infill Cooling Temp Extruder Notes # Unsupported area threshold Bridging extrusion multiplier Bridging speed multiplier Default Speed Primary Height Interior fill Outline Overlap Fan Temp Retraction Dist. Extra Restart Dist. 3 NA NA NA NA NA NA NA NA NA 5 9 80 175 2400 0.1 20 35 YES 230C 1.00 0.00 Filament detaching as it left tower so no connection. 6 9 25 60 2400 0.1 20 25 YES 230C 1.00 1.00 Complete failure. Complete detachment as head moved to next tower. 1 9 100 100 1800 0.25 20 15 NO 235C 1.00 0.00 2 9 50 200 1800 0.25 20 15 YES 235C 1.00 0.00 4 9 90 200 2400 0.15 20 25 YES 235C 1.00 0.00 7 9 70 200 2100 0.15 20 30 YES 230C Retraction OFF Retraction OFF Great bridges. Just a couple very minor sags. But, very stringy. Retraction OFF is obvious. 8 9 70 200 2100 0.15 20 30 YES 230C 0.50 1.00 Great bridges. A little less stringy. Need to work with retraction a bit more. Bambu P1S/AMS
08-08-2014, 01:22 PM #43
On that 'nice' print in the photograph, the bottom side is almost as good, but there are some strands that did not adhere. I'm half tempted to go grab the Slicer source and add an extra parameter. I want a setting that lets me say how much extra to extrude just prior to starting or just after ending a bridge operation. I'm thinking if the nozzle parked right at the edge where the bridge is going to run, and a user selectable amount of filament is extruded to force a 'tack', a lot of my bridge problems go away.
Alas... I don't know Python.
08-08-2014, 04:19 PM #44
Same here.
My bridge is really nice too but there was just one strand that didn't tack on both ends. Your idea to add a parameter is exactly what it needs. When I turned off ozze control, I had really good bridges. I think there was a slight retraction just prior to starting the bridge. It needs the opposite to, like you say, tack the filament down.
I am using Simplify3D now and it allows you to have different controls on different layers. I'm going to play with building a specific set of parameters (they call it a profile) for the first bridge layer and see what results can get. I've just had S3D for a week so I have a lot to learn. It might be able to give me better bridges, although, I'm pretty happy with what I have now considering.
Come on, you are so good with other code, you can learn Python overnight...yea?...lol...
Seriously, there does need to be some extra bridge parameters. I bet Skeinforge has it. I played with it a bit and became less intimidated by it. But in the end, other slicers were just so much easier so I haven't touched it lately. If I recall, it had lots of parameters that could control bridges.Bambu P1S/AMS
08-08-2014, 06:04 PM #45
- Jul 2014
- 305
Thank you so much for all of this information! I am so happy to see the amount of information in this thread. It really helps me and I am sure it helps others.
I am becoming more confident in printing. I am still learning about raft's and when they are needed and working with bridges.
RobH2 I may check up with you in a week or two, I am really interested in Simplfy3D but not interested in the price. I did notice that slic3r has an experimental version out that looks promising.
08-08-2014, 07:46 PM #46
Sure, no problem. I'm glad you are finding this forum helpful. We have some great people here.
I wasn't excited about S3D's price either but even as much as we all like free stuff and open-source stuff, there comes a time when having a budget to develop something brings with it advantages. I've tried just about every free slicer out there. I even spent two hard weeks with Skeinforge. If you want to exercise your brain and magnify your weekly beer requirements, dive into that one. I became less afraid of it and built up a lot of respect for it but it suffers from what a lot of potentially good software does, lack of interface design. It's intimidating because it's just a mess visually.
I like using Cura because of the great 3d window. But, I like Pronterface for the connection to the machine and easy controls. I like KissSlicer because it's the cleanest printing slicer I've ever used but it's SD Card only, no USB connection. So, no matter what slicer I was using, I always kept Pronterface open so I could connect and control my machine manually. I know there are some recent interconnections that are promising but I just could not find and all-in-one slicer. I was searching for something that did it all. If 3DS Max integrates 3d printing in to the next release, watch out. That would be incredible especially if they were able to top Simplify3D. You'd then have a truly powerful single piece of software as you'd be able to design a part and print it without ever closing a window.
I wrote Simplify3D and asked if they had a demo. I already knew the answer because I'd done a bunch of reading but it can't hurt to ask. While I waited for an answer, I viewed every single tutorial and read the entire site. It doesn't take too long because oddly enough, they don't have a manual. What I decided was that in reality $140 was not going to break the bank. Thats only 4 rolls of filament. So before I had the answer, it was, "no" by the way, I had already purchased it. I have to say, it's not perfect yet but it comes pretty darn close. I don't think anyone would complain about the $140 after using it for a few weeks. I'm really starting to like it and believe that it will be come my only slicer.
So don't be afraid to jump in with both feet. That's the way to bolster that confidence you are building. You'll wind up with a pile of useless prints but you'll learn so much along the way. I learn something new every time I print and it just as fascinating now as it was a year ago when I built my printer.Bambu P1S/AMS
08-08-2014, 11:46 PM #47
- new jersey
- 752
i have to say that i have been using only simplify 3d for over a year now. i dont even mess with anything else. great piece of software. as rob said its not perfect but has made leaps and bounds since i first bought it. it still has the occasional bug but noting that has ever kept me from having full functionality. the one good thing about just using that one slicer instead of bouncing around trying them all is that i know it really well and how it works with my printer so i can usually just look at my model and know exactly where all my settings need to be without really thinking about it too much. the one thing it does seem to lack on is dual extrusion. from guys with dual extruders they say it could use some improvement in that area. in due time though.
08-09-2014, 12:59 AM #48
Jim, you make a good point. First of all, with the expertise you have, to hear you say that after a year you are still impressed with it is good news. I too find it quite nice.
Your point about bouncing around is a very valid one. It's really difficult to zero in on defects when you are trying to use 3 different slicers to get results. All of them like "different" subtle changes to perfect prints and it's really impossible to get really sensitive to those if you don't stop and focus on just one slicer and get to understand it. Like any good scientific experiment, if you change multiple parameters at a time you lose track of the experiment and gain little. I can see the same with slicers. I'm going to throw my self at just one for awhile and see if I can't wear it out.Bambu P1S/AMS
08-18-2014, 11:40 PM #49
- Jul 2014
- 305
So I have been having some problems recently. Of course the minute I figure out how to print and what my machine likes I run into issues.
I was trying to change my filament colour and my machine would not let me pull the filament out. So I took it apart and finally removed the filament. I then loaded the new spool and it was feeding just like it normally does. But now when I try to print it under extrudes and the motor that pulls the filament makes a clicking noise like it cannot grab the filament and feed it will. I inspected the feeding gear and it is clean and free from filament.
The only thing I can think of is the nozzle is clogged. I am going to try to remove the nozzle and see if I can clear it but I am afraid of damaging the threads.
08-20-2014, 09:09 AM #50
blkkrow, what kind of extruder do you have? It does sound like a hard jam. Some piece of debris may have gotten in and is blocking the hole. Do you have a dust remover on the filament before it goes into the extruder? http://www.thingiverse.com/thing:16483
I've found a very good way to clean out clogged nozzles. Here is a link. http://3dprintboard.com/showthread.p...ll=1#post22713 (Post #13 incase the link is not going to the right place).Bambu P1S/AMS
New member with print issue
Yesterday, 08:57 AM in Tips, Tricks and Tech Help
