Results 1 to 10 of 129
08-08-2014, 06:09 PM #11
We have a pile of objects we give out as free samples, and the barbie-pink stretchlets are always popular with little girls, so I put on a batch of 5 to run overnight. It was also a test to see if building multiple objects went any faster than the sum of individual objects, other than only having to go through the 15 minute prep cycle at the beginning of the build. Below, you can see how the non-level bed is affecting the first layer. One nice thing is that we didn't get a filament jam from having the extruder tip shoved so hard onto the tape that nothing could come out.
You can see what happened to this one where it had the opposite problem, too much Z-height zero. I expect this will be fixed once we get the bed leveling issue squared away. I'm giving Makerbot the benefit of the doubt that the new extruder may have some kind of chance of affecting the bed leveling. No who am I kidding. I just need to go through the exercise so when I call them back they can get a clue that not every 5th Gen issue is either a bad extruder or old firmware. Oh and I did check the firmware, it is indeed the latest, 1.2.112. That's done through the host software, Makerbot for Desktop. I had really been holding out hope that one of these magic firmware updates would somehow speed up these build times.
Unfortunately, building multiple objects does NOT speed up the build time any, it is simply the sum of the build times individually.
