Results 1 to 10 of 15
Thread: The Story of my NEO
08-04-2014, 09:15 AM #1
- Jul 2014
- Munich
- 45
The Story of my NEO
Hi all
I decided to write few words about my NEO maybe thay can help other,
A few weeks ago I decidet to try the NEO as a small backup of my Protos,
After arriving my first Problem were to stay ?
(too many projects at the same time no free space)
So I put him on the bar of my open kitchen, the space was perfect my small netbook connecting and he was ready to start.
First Printout with the satandart profile and i was surrprised with the result.
I creat this bec one of my rolls was to big for the standard one.
next point I would like to change was the lightning it was simple to dark inside,
so i create a LED Ring Holder.
Much Better. ( I now heard there will be a light line in the GRRF shop soon, too late for me)
My next step was the Buldtack printbed I already destroyed it.
so after research in the GRRF Forum I readjust the printbed on a Level that the Filament will only pressed on a bit (its nearly only a lay down)
With a new Buildtackfoil I started again (and this one is still my Printbed).
so this was solved, but I think everyone know the bad sides of PLA so a fan solution for the Filament need to be found.
I created a few ones but run out of time but someone else created one so I removed my LED Ring and mounted the fan holder( and a new light system)
Looks not bad so I started testing and the result were great.
Yesterday I get a small accident but waht I could see ther was cool
Middle in the print the head moved 1cm but he was printing bridges !
the best bridges I could seen from my printers ever
the left one are 3 lines the 2 middle ones 2 and the right one 1
and a bit you can also see the walls for a printer with this size and price great.(0.2 layer size)
From start to now the printer have now more than 10 days printing time.
I´ll see what happens next if intresting for someone I´ll update this post from time to time
Best wishes
Thomas
PS: alle models can be found on thingiverse, if the cabeling is intresting let me know than I post a description how to install.Last edited by Luchador; 08-05-2014 at 12:06 AM.
New member with print issue
