11-10-2013, 07:01 PM #1
- 259
Rapide One 3D printer To Luanch on Indiegogo Next week
This is a pretty futuristic looking 3d Printer, which will try and seek funding on Indiegogo starting on November 18th. The printer, called the Rapide One, will retail at $2499. If you wish to back it on Indiegogo upon launch though, you will get a nice deal, $1499.00. Here are the specs of the Rapide One:
- Positioning Precision: XY: 11 microns ; Z: 2.5 microns
- Print Weight: 21 kilograms
- Diameter of Filament: 1.75 milimeters
- Chassis is made out of Aircraft Grade 7 Aluminum
- Stepper Motors: 1.8 degree step angle w-1/16 micro-stepping
- Layer Resolution Settings: High: 100 microns / Standard: 200 microns / Low: 300 microns
- Diameter of the Nozzle: 0. millimeters
- Body is made out of Aluminum, Glass, and PVC
- Supports: Windows (XP 32 bit/7+), Ubuntu Linux (12.04+), Mac OS X (10.6 64 bit/10.7+)
- Build Platform: Heated, polished 356F Aluminum
More details at: http://rapide-3d.com/printer01.php
New member with print issue
