Results 1 to 10 of 57
07-19-2014, 03:36 PM #10
That is normal, the print head sags very slightly in the middle. I usually level the bed perfectly with a postit note, then every so slighty tighten each thumbscrew just a tiny amount. Do all 3 the same. But it will print fine when the print head is a little closer to the build plate.
It helps if you decrease the weight of the print head by removing the unused stepper motor at least when not in use.
