Results 1 to 9 of 9
Thread: FlashForge Dreamer Feedback?
07-09-2014, 07:24 AM #1
I'm strongly considering purchasing a FlashForge Dreamer. Has anyone had the opportunity to use one of the final Dreamers yet? I know they released some beta versions a while back but I believe they have made improvements to them. I'd be interested in seeing what your thoughts are on the final Dreamer that released a few weeks ago.
07-09-2014, 09:01 PM #2
There is some Dreamer videos on youtube from Thomas James. A few are on the google groups, but the Pro seems to be more popular.
07-15-2014, 05:04 AM #3
- Apr 2014
- 21
08-09-2014, 04:27 PM #4
At 3DPrint.com we recently were supplied with a Dreamer, and so far so good. Very impressed with the results so far.
Eddie
08-09-2014, 04:51 PM #5
08-14-2014, 09:12 PM #6
- Aug 2014
- 6
I bought a dreamer after watching thomas james's videos. over all Im happy with it. its my first 3d printer. but It is made of plastic so it comes across as having a "cheap" feel but honestly Ive been very happy with the prints and that dual extruder the fact that I can use ABS or PLA heated bed is good. the only issue I have and I think every dreamer owner has is wifi printing doesnt quite work. James said in a video thats a firmware issue thats supposed to be fix in a update. not really holding my breath but SD card printing is easy. Hope that helps.. if you have any questions I'll be happy to answer as best as possible.
09-18-2014, 10:37 PM #7
- Feb 2014
- 10
HI, just received the FF Dreamer few days ago, but having trouble printing this with flashforge white ABS (included):
http://www.thingiverse.com/thing:215703/#files
I used to own Up Plus 2. That printer printed the object nicely.
I have used support, 30mm/s speed, but still the result is not satisfying.
If you guys have a chance to try it and succeed, let me know the tricks. Thanks.
and for Rovino, I have trouble with wifi as well. I wonder if there is any firmware update for the wifi.
09-19-2014, 09:37 AM #8
- Jul 2014
- 14
I assume that it is a single extruder...also can any brand of ABS spools fit in there, or do you have to use their own ABS spools?
Does this have a heated build plate?Last edited by roguesqd; 09-19-2014 at 10:00 AM.
09-23-2014, 06:11 AM #9
you definitely shouldn't need supports for marvin.
A fan on the print really helps - not sure how easy that would be on a dreamer, but I'd assume the the standard ducting setup we use on the creators should work. It's the same extruders on the dreamer isn't it ?
It's essentially an enclosed creator - but with it's own firmware. Not sure if that makes it more compatible with 3rd party software like cura and slic3r - or less.
