11-07-2013, 11:14 AM #1
- Ireland
- 11
Android app to control reprap and simulate gcode on your device
Hey all. Came across this promising app. It's an Android app that will allow you to control your reprap from your phone instead of using a computer as a host. Very handy when your significant other would like to use the lap top while you've got a job running.
It is also able to simulate what your gcode will look like. Allowing you to check how your print should turn out, making it easier to spot errors and fix them instead of wasting precious filaments.
Unfortunately it doesn't run with my version of Android(2.2.2) but looks like really cool work.
http://www.dietzm.de/gcodesim/#GCodeSimulatorPrinter
11-07-2013, 11:26 AM #2
- 96
I wonder what happens when you get a phone call.
11-07-2013, 12:00 PM #3
- Ireland
- 11
You'd probably end up with a 3d printed version of the person calling you.
As far as I can gather the printers software does not use up too much computing power.
The raspberry pi can control a printer so I'd imagine the app would probably just keep running
In the background until you've finished your call. You'd probably have to use an SD card on the printer for the gcode
And then use the phone to run the code and keep an eye on temps.
11-07-2013, 05:16 PM #4
11-10-2013, 05:09 PM #5
Edit: This is a standard .JAR file and can run on anything with Java - Not just Droid (won't run on iOS).
This is a GREAT piece of code. I use it on Windows and OSX all the time.
When I'm ready to do a large print, or a commission ($$) print, I will run their STL through Netfabb to ensure it is clean and working, then send it via GcodeSim to get a more accurate time (or close estimate) and you can also use the top and side views to see if all parts have printed correctly - I had problems with my i3 dual extruder not printing filament paths for 2 days until I realised!
12-27-2015, 03:16 AM #6
- Feb 2015
I'm very excited to announce a new version of #GCodePrintr - The 3D Printing App for Android.
Version 2.5 comes with many improvements and several new features, which will help to maximize the capabilities of your 3D printer.
Many features are based on input from the GCodePrintr community: Thanks for your feedback !
GCodePrintr App is used by >2000 users
The new version is available on Google Play (staged rollout just started)
See http://3dprintapps.de/version25.html
*New Features:*
New 3d View
New Tutorial guide
German translation
New "Recent Files" dialog
New "Fit to Screen" Zoom feature
New Macros - Filament change macro
Move aside when pause
New "Print completion Dialog" and Sharing feature
Easy way to enter Temperatures
Macro special keywords
CH341 serial chip support
Support for non-square and custom bed size
Paint non-print moves (travel) as full lines (for CNC)
Tasker Intergration
And more......
