Results 1 to 10 of 757
06-25-2014, 06:12 PM #10
- 37
cut and pasted it, you can see I typed lower case n into the command line but it says sending in all caps. I cant change that.
Sorry my bad i just switched everything back on and tried it again, i didnt realise that it would auto capitalize the whole line if the G was lower case. That was why the other parameters were still working as they work in upper and lower case. Id been putting it in as g29 n5 as this has never been an issue before. Next thing is to try a test print and see what it does. Thank you so much.Last edited by brainscan; 06-25-2014 at 06:23 PM. Reason: Im an idiot
