Results 1 to 10 of 10
06-22-2014, 06:00 PM #1
- Dec 2013
- 49
What materials will work on the strooder?
Are we limited to just PLA and ABS on the Strooder or do other materials work as well? Nylon? Rubbers? Anything else?
06-23-2014, 02:42 AM #2
What day to day life plastics can we recycle ?
12-01-2014, 04:10 AM #3
We have been experimenting with different types of plastic to see what Strooder can extrude, in theory any thermoplastics that melt below 250-260C. We have successfully extruded both PET, HDPE. We are looking to see what else can be extruded, We really want to encourage recycling and are looking into all of the 'every day' plastics we can recycle. However @ LambdaFF I noticed on your chart there is PVC, which is quite a dangerous plastic, certainly for home use as it can produce Hydrogen Chloride gas and Hydrochloric acid. It is always recommended to look up datasheets for any plastic you want to extrude. We will be providing an easy to use datasheet for common plastics on our website and potentially as a leaflet provided with the Strooder along with recommended settings for best results.
12-05-2014, 04:08 AM #4
Looking at various items in my closets, I see a lot of the following :
PET,
PP,
HDPE,
LDPE
What is your take on those ?
Regards
12-08-2014, 07:20 AM #5
Those are all suitable polymers for extrusion at home and will melt within Strooder's temperature range. The only thing we need to test is the optimal conditions for tolerances, and how 'recycle-able' they are.
We're planning to open a thread specifically to log all of our filament experiments, I'll keep you posted for when that appears.
02-19-2015, 05:14 AM #6
If you can't tell : we're eager to receive the machine.
02-19-2015, 05:31 AM #7
That is awesome, we are eager to get it to you!
02-19-2015, 09:10 AM #8
02-19-2015, 10:35 AM #9
02-19-2015, 10:44 AM #10
Yes, it sounds great, that way the community can add to it. A data sheet to include with the Strooder, as you suggested, would also be a great idea. Looking forward to the results.
