Results 1 to 10 of 10
06-18-2014, 04:38 PM #3
I'm also using cheap, thin glass. I got it at a Craft store for use in picture frames. I specifically wanted thin glass because that would help the surface be closer in temperature to what the heat bed is at. I also wanted thin glass because I used my Dremel tool with a diamond burr to drill holes in it for my spring loaded mounting screws to go through it.
So far no problems with cheap, thin, normal picture frame glass!Last edited by ciutateivissa; 06-18-2014 at 04:46 PM.
