08-27-2023, 01:05 PM #1
- Aug 2023
Ender 3 V2 - Continuous Nozzle Clogging
I recently bought a used Ender 3 V2 printer and the first two simple and short prints went relatively smoothly. However, when I attempted a 7-hour print consisting of three parts, one element got cut off due to a clogged nozzle. I reprinted that element and it worked fine, but now I'm trying to print a part that takes around 10 hours, and each time the nozzle gets clogged after about 1-2 hours. I've tried three times already, and I even replaced the nozzle, but the issue persists.I'm using filament that came vacuum-sealed with a moisture-resistant bag, which arrived yesterday.
I'm using the filament :
PLA Colorfil Filament - Material Characteristics
Manufacturer: Colorfil
Base Material: PLA
Filament Diameter: 1.75mm
Tolerance: ± 0.05mm
Net Weight: 1kg
Printing Temperature: from 190ºC to 230ºC
Bed Temperature: from 0ºC to 60ºC
Bed Temperature: set the nozzle temperature to 200 degrees and the bed to 60 degrees. I'm using the standard settings in Cura.Please,
I'm looking for advice on what to do next.Last edited by cordex; 08-27-2023 at 01:12 PM.
Login Error
