Thread: Need Help From Printing Gods!
07-17-2023, 09:57 AM #6
- May 2020
- 626
Have you cleaned the bed with a wipe over with some IPA before each print?
It could be that you need a new bed sheet, the reason I suggest this is that I tend to print ASA and never really had bed adhesion problems, I frequently cleaned the bed sheet with IPA. However I recently decided to use some PLA I had and it would just not stick to the PEI sheet at all.
Replaced the PEI sheet for a new one and had no probems.
I do give the bed a wipe with IPA before every print.
I thing that perhaps the constant use of ASA might have left a film of sorts on the bed and this prevented the PLA sticking. Next time I use ASA I'll be trying the old bed sheet again.
If ABS acts like ASA and warps it will help if the printer is enclosed and you make no efort to open it until everything has cooled back to ambient.
Perhaps try a glue stick to see if it helps.
