Results 1 to 10 of 11
06-08-2014, 09:12 AM #6
Got mine last week. Made only a very simple print for initial testing using the flashforge software, and they turned up ok. It's also my first bot so I can't give you a good comparison. When I opened up the box my horizontal X axis was clearly a bit out of square so a had to loosen up a screw and fix it by hand, also I think I can get a better print quality by tuning up the settings or changing to a more complex g code software, but info on the right parameters is really scarce right now, gonna try to start off with the "creator" settings and work up from there. I was happy with the wifi settings, the printer can work similar to a wifi router, providing is own network that your pc can connect to, or it can work as a regular wifi printer that gets connected to your existing wifi network.
