Results 1 to 8 of 8
11-05-2022, 04:27 PM #1
- Nov 2022
- Southern Utah
Vertical walls not sticking to one another
I am fairly new to 3D printing and not sure what the correct terminology is. The problem I am having is that my walls (perimeters?) are not sticking to one another. At the top of any wall, I can run my fingernail across the top edge and pull the wall sections apart. See the image for an example. I think the issue could be under extrusion but I have tried the print on two different printers, and one of them is almost brand new and has a micro swiss geared direct drive. Both printers give me the same results. I have tried several things like slowing the print down, increasing the temperature of the PLA, changing wall thickness, changing z-seam to "shortest" - I have tried the same 3mf and stl files on both Cura and PrusaSlicer. I am at a loss for what is causing this to happen. Has anyone had this happen before? I am creating my files in Fusion 360. My two printers are an Ender 3 pro and an Ender 5 Plus. Thanks in advance for any help.
11-06-2022, 07:09 PM #2
- Jun 2022
- The great state of Texas
- 152
Do you mind sharing the stl file? I am curious if there is anything going on with it since you have tried different printers with different settings.
I have not had anything like that behavior in my printer, though I have only been 3d printing for about 4 months.
11-07-2022, 09:22 AM #3
- Nov 2022
- Southern Utah
Here are the files. I have included a 3mf, gcode, and stl(binary).
https://drive.google.com/file/d/1GK6...ew?usp=sharing
11-07-2022, 11:22 AM #4
- Jun 2022
- 152
I wish I was more help.
The file looks fine. I threw it into my machine and it printed fine.
Here are the settings I used on CURA and a picture of the print. Sorry, best of luck. Hopefully someone has the answer.
11-07-2022, 05:28 PM #5
- Nov 2022
- Southern Utah
OG56,Thanks for tying the files out. While it may not solve the problem, it makes me think that the issue is with the printers. I will try and find something similar online to test print and see if I still get the same issues.
01-15-2023, 01:43 PM #6
- Jan 2023
- 36
You might need to use supports for a over hang like that and also maybe level the bed Have a great day
01-15-2023, 02:12 PM #7
- May 2020
- 632
01-15-2023, 09:43 PM #8
- Jan 2023
- 36
on the inner side of the box where the wall is coming off
New member with print issue
