Thread: Thicker infill walls
12-01-2022, 05:35 AM #1
- Nov 2018
- 11
Hi
Do any of you know if you can make the infill walls thicker? Not the density but the actual wall thickness of the hex walls, say 2 counts rather than a single wall as seems to be standard?
I'm using flashprint 5.5.2
Cheers
Mike
12-01-2022, 05:41 AM #2
- May 2020
- 627
There's usually a user adjustable slicer setting to set number of walls.
12-01-2022, 06:18 AM #3
- Nov 2022
- 18
I believe that setting is under the Infill tab, you can increase the Strength Infill, Solid Layers setting.
12-01-2022, 06:46 AM #4
- Nov 2018
- 11
12-01-2022, 06:48 AM #5
- Nov 2018
- 11
12-02-2022, 05:53 AM #6
- Nov 2022
- 18
Sorry, I'm still learning Flash Print myself, so no expert advice from me.
What about under the Infill Tab, Combine Infill, the Maximum Solid Combine setting description includes "infill will be thicker while thickness of the perimeter keeps unchanged".
Setting that to 2 might do what you want.
I really like using Flash Print more so than other slicers, and calibrated my printer using Flash Print, and not ready to go through that again with another slicer yet; too many things to print now.
So I'm interested where this setting is in Flash Print too.
12-14-2022, 09:45 AM #7
- Nov 2022
- 18
This guy does it with Extrusion Width:https://www.youtube.com/watch?v=9YaJ0wSKKHAThough this somewhat will impact dimensional sizes too.
