Results 1 to 9 of 9
11-15-2022, 10:05 AM #6
start with the most you can afford.
THen what the biggest thing you might want to make is.
Then what type of thing you are likely to make the most: practical stuff, models, toys etc
Then what materials you might want to use. (ie: sub 250c print temp or Above 250c print temp)
And at that point you can start putting a list of specs together and start looking for a printer that matches the specs as well as can be found :-)
New member with print issue
