10-31-2022, 06:52 AM #3
- Oct 2022
235V going into the PSUA steady 24.3v DC coming out. --- I wouldn't suspect the power supply is bad unless it's spiking for some reason. -- So you may be right, just a bad driver. That leaves me with a few questions before I swap out the driver. 1. Would a bad driver cause the entire machine to turn off? I would guess it would stop printing and just display an error if it was just the driver. 2. What would cause the driver to go bad? It's the Y axis driver that burnt out. The cable from the driver to the stepper motor is fixed and is perfectly fine. The motor turns fine with no resistance. -- Here's an image of the bad stepper -- https://ibb.co/VmR3zRr
