09-06-2022, 09:22 AM #1
- Sep 2022
how to upscale a 3d file to match my measurements
Hi all,basically, i have downloaded this file https://www.thingiverse.com/thing:3723903 and need to upscale it to fit a 60ml syringe.it's for my great nan as she has to be fed via a feeding peg and she struggles to plunge the syringe when full of her feeding liquid.i have no idea on how to do this, i have the syringe with me and some calipers but no idea on how to use them any info would be much appreciated
09-06-2022, 10:21 AM #2
- May 2020
- 623
Suggestion...import the STL file into your slicer and you should be able to adjust the size there up or down ready to export it as a G-code file.
09-06-2022, 11:10 AM #3
- 885
@TayZc1, I found an amazon item that presents the dimensions: https://www.amazon.com/Pack-60ml-Syr.../dp/B07H3MH52R If you can confirm that these values match the item you have, it provides a starting point. Using the 20 ml model in the link you provided, I measured the opening for the syringe. It appears that the 20 ml syringe requires about a 21.5 mm diameter to fit in that model. The amazon link indicates a 31 mm diameter, which scales up by 144 percent. It's possible that you'd want to go a bit larger, perhaps 145 percent, but too much could create slop in the design. At least with upscaling a part, it becomes less fragile as a result. Using the 144 percent figure, I've scaled the objects using Meshmixer and attached them. Obviously, you'll want to ensure that the length is appropriate. That's a parameter I did not check. I'm hopeful that adjusting the inside diameter of the female portion will provide for proportional matching of the syringe.
