Thread: how to fix this problem
09-03-2022, 06:02 AM #4
Now that we can remove the obvious, it could be determined that one or two other solutions could be tried.
1: you could be experiencing over extrusion you could reduce the flow rate and see if this eliminates bumps.
2: you could have moisture in filament, placing a dollar store Charcoal Moisture Eliminator in your filament storage container could help.
Drying filament could be needed the best way to eliminate moisture is by using a food dehydratorLast edited by Roberts_Clif; 09-15-2022 at 07:57 AM.
