06-21-2022, 11:31 AM #1
- Mar 2022
How to Install Attic Insulation Over Existing?
You probably already have some insulation in your attic and may want to increase your R-value. Are you wondering whether it is possible to add new attic insulation over existing insulation? It is possible, and you probably should not have to remove your existing layer to get more out of insulating your attic.
By installing insulation in your attic, you will be able to reduce monthly utility billing very easily. Plus it also helps to improve the overall energy efficiency and provide excellent comfort for long years. Moreover, insulation is easy to install and can be finished in just one week.
Right here we will explain to you a quick guide about how you can install attic insulation by following some easy tips. We have also discussed its approximate cost for you.
