Results 1 to 10 of 17
Thread: What will improve this ?
05-03-2022, 10:38 AM #8
print settings usually consist of outlines, top and bottom layers and infill.
I usually use 3 outlines, 3 top and 3 bottom layers.
But for somethings a single outline works better.
You can also go with no outlines and have everything infill.
this print has 3 outlines.
The slicer considers anything bordering a void to be an edge, so uses outlines.
It could well be the putlines that are causing your ghosting.
If you try it with 1 or 0 outlines, could fix the issue.
All I can think of, either that or something to do with the extrusion process.
