Results 1 to 8 of 8
04-26-2022, 05:07 AM #3
- Apr 2022
- 6
I have varied the speeds and reduced the retraction to 2mm, even turned it off on one print
I tried the same model with Cura my default, and Prusa. Both prints failed the same way, at the same level, (6) the Prusa one was using the stock settings for the most part. Cura was tweaked to what I know worked with this PETG
The only sucsessful print that I got was a 13mm square cube for a robot vacuum brush hub, and even then I did hear the occasional "click"
Waiting for time to do all of the mods at once
These recent prints are small, bowden tube has a gentle sweep to the hot end, and the print is only about 80mm x 50mm
I level bed prior to every print, and watch the first layer to make any fine tuning needed
Prusa Sliced
Cura Sliced
