04-01-2022, 12:14 AM #1
- Apr 2022
Creality CR-10Max Freezes in mid air
I'm total noob when it comes to 3D printing, so i have no idea what is going on with this.See the issue on youtube: https://youtu.be/OawB57d5XrY
Cura G-Code:
Start:
M201 X500.00 Y500.00 Z100.00 E5000.00 ;Setup machine max acceleration
M203 X500.00 Y500.00 Z10.00 E50.00 ;Setup machine max feedrate
M204 P500.00 R1000.00 T500.00 ;Setup Print/Retract/Travel acceleration
M205 X8.00 Y8.00 Z0.40 E5.00 ;Setup Jerk
M220 S100 ;Reset Feedrate
M221 S100 ;Reset Flowrate
G28 ;Home
G29 ;Auto bed Level
M107 ;Turn layer fan off
G92 E0 ;Reset Extruder
G1 Z2.0 F3000 ;Move Z Axis up
G1 X10.1 Y20 Z0.28 F5000.0 ;Move to start position
G1 X10.1 Y200.0 Z0.28 F1500.0 E15 ;Draw the first line
G1 X10.4 Y200.0 Z0.28 F5000.0 ;Move to side a little
G1 X10.4 Y20 Z0.28 F1500.0 E30 ;Draw the second line
End:
G91 ;Relative positioning
G1 E-2 F2700 ;Retract a bit
G1 E-2 Z0.2 F2400 ;Retract and raise Z
G1 X5 Y5 F3000 ;Wipe out
G1 Z10 ;Raise Z more
G90 ;Absolute positioning
G1 X0 Y{machine_depth} ;Present print
M106 S0 ;Turn-off fan
M104 S0 ;Turn-off hotend
M140 S0 ;Turn-off bed
M84 X Y E ;Disable all steppers but ZLast edited by Dariv; 04-01-2022 at 04:08 AM.
04-01-2022, 07:32 AM #2
It appears that the Z-End-stop / Proximity sensor is not working correctly.
I would connect printer to USB to your computer, using a terminal program like Pronterface an send M119 to get the status of you end-stops,
04-01-2022, 03:43 PM #3
- Apr 2022
VIVA AMERICA !!! Thank you! Solved
