Results 11 to 18 of 18
Thread: Cleaning the kapton
04-20-2014, 06:06 PM #11
04-20-2014, 09:32 PM #12
05-24-2014, 12:23 AM #13
- Apr 2014
- Echuca Victoria
- 60
Hi All,
Well first attempt at applying kapton tap, tried the mist spray idea and all looked good until bed heated up and the evaporation caused bubbles everywhere, build plate looked like a piece of bubble wrap.
Next attempt putting tap on cold bed, umm like this truly was a nightmare and wasn't happy with result.
Both first two attempts done with heatbed out of the machine.
Third attempt I left the 2nd attempts kapton in place, heated the bed to 100 degs, turned off heating and then just lifted kapton off one halk and re-applied just using finger pressure to smooth it out, then repeated task for other half of bed.
What did I learn.....Much simpler to take bed out, put on kapton roughly then put back in machine, heat bed and simple as to smooth off, not even the slightest crease or bubble anywhere.
One last thing of importance if trying this method, buy a pair of superfine cotton gloves, I didn't have any and lets just say fingies got rather warm.
Anyway it worked and never wasted a single piece of kapton tape.
Cheerss
05-24-2014, 12:51 AM #14Hex3D - 3D Printing and Design http://www.hex3d.com
05-24-2014, 03:00 AM #15
Sounds like this is one time you can get away with doing a half-arsed job!
OME
05-27-2014, 07:55 AM #16
- May 2014
I have found that if you make a strong mix of sugar and water and wipe it over the hot bed it makes things stick. and after it just cleans up with a warm damp sponge.
05-28-2014, 10:21 AM #17
yeah I use sugar soap (from the hardware store) which I guess is pretty similar that.
05-29-2014, 11:50 PM #18
- Apr 2014
- Echuca Victoria
- 60
Back finally,
I have been using computer wipes from Big W, branded under the clean range. Every print has adhered perfectly to the bed and the wipes leave no residue.
Cheap as they come and extremely effective.
