  1. #1
    Student
    Dec 2021
    Location
    Wuhan
    Follow EasyMFG On Twitter Add EasyMFG on Facebook
    What is the largest sand 3D printer you have ever seen?
    In my case, the largest 3D printer I've ever seen is the EasyMFG3DP-S2200?easy3dp-S2200.jpgEasyMFG3DP-S2200 Image
    Equipment Easy3DP-S2200
    Build Box 2200mm×1000mmx1000mm
    External Dimensions 4400mmx2050mmx1900mm
    Precision ±0.2mm(200mm)±0.1%(L?200mm)
    Tensile Strength 1-4Mpa
    Surface roughtness Be superior Ral12.5
    Gas Evolution Rate 12-20ml/g(850)
    Printing Speed 10-50 s/per layer
    Layer Height 0.1-0.5mm(can be adjustable)
    Printheads four piezoelectric printheads(Can be equipped with up to 8pcs)
    Specicification for printheads Length?72mm,resolution:360DPI
    File Format STL,3MF
    Electrical Requirements Three phase,380V,16A,50HZ
    Powder types Silica sand,quartz sand,precoated sand ,etc
  2. #2
    Jul 2014
    pretty sure I've seen bigger :-)
