Results 1 to 10 of 10
Thread: Hollow print. Help.
01-01-2022, 07:54 AM #1
- Jan 2022
Hollow print. Help.
Hello all.
I recently bought my first 3D printer (Ender 3Pro) and I have some problems , tried to print a telescope mounting for a phone but the print came out not too good , kind of flimsy ,and not what I had expected or hoped. (White) .
I said it's probably the supplied (from the company) sample PLA and switched to a reel of real filament PLA standard 1.75 thickness , and tried a print for a friend but the layers still weren't quite sticking to each other so i bumped the nozzle temp up by 5 C. and it kind of worked after some time but not really .
Any ideas on what is wrong or how to fix it??
Anything helps , thanks in advance
IMG_20220101_155618.jpgIMG_20220101_160130[1].jpgIMG_20220101_160206.jpgIMG_20220101_155626.jpgLast edited by Airkout; 01-01-2022 at 08:29 AM. Reason: Stupid me forgot to add the pictures
01-01-2022, 11:13 AM #2
In order to help you could help us by posting your Slicer and slicer settings.
01-01-2022, 11:15 AM #3
- Jan 2022
Right now i am using creality slicer 4.8.2
for settings they are not the same
i am using 20% infill with .2 per layer
01-01-2022, 04:14 PM #4
- 885
What temperature are you using on the extruder?
01-01-2022, 05:53 PM #5
The creality slicer 4.8.2 slicer is one of the oldest slicers out.
In fact it is Cura 15.04.6 shown in the image below.
I have Cura 15.04.6 and on occasion still use Cura 15.04.6 though it is really old. I mainly use PrusaSlicer which is Slic3r with some really excellent upgrades or newer versions of Cura.
Where I have several profiles configured from my original Cura added to all newer Slicers and they have proved to work great for my current needs.
01-02-2022, 04:06 AM #6
- Jan 2022
01-02-2022, 04:19 AM #7
- Jan 2022
Newest print with 208 temp in most of the print 210 on the last part and higher flow of material up to 111(stock on the printer 100)
IMG_20220102_120708.jpgIMG_20220101_183643.jpgIMG_20220102_120708.jpglast print.jpgLast edited by Airkout; 01-02-2022 at 04:27 AM.
01-02-2022, 04:36 AM #8
- 885
I can't read the wall thickness in the posted image, but that might not be a concern. I see the layer thickness is 0.28 mm, which is very close to the maximum for a 0.4 mm nozzle. Have you tried a smaller layer thickness? Using a layer thickness of 0.2 mm is pretty common.
Consider also to try a different slicer. PrusaSlicer is quite capable, may have a profile for your printer, is free and easy to use and may shed some light on the problem.
01-02-2022, 04:55 AM #9
- Jan 2022
Ok first of all i am kinda stupid that i said creality cause i had latest version of cura installed and that is what i had used , wall thickness is 0.8 also i tried lower quality(.28) to see if it resolved the issue I had with the dog , witch it did but it came out looking like it's made from spider webs or smth
01-02-2022, 06:53 AM #10
Airkout
Posting the Cura Profiles created and use daily to 3D Print using a .4 nozzle up to .32mm successfully.
.32mm is max layer height at 80% of the nozzle diameter.
Give them a try and see if any will help your 3D Printed models.
For Cura 15.04.6 / creality slicer 4.8.2
If these profiles work and you want to try PrusaSlicer will post profiles or the Newer Cura versions Profiles
Sample 3D Printed Model below using single extruder printer.
