Results 11 to 16 of 16
01-20-2021, 03:00 PM #11
- Jul 2020
- 11
Hello Mo,I should have asked this question way long time ago. What operating system are you using? I was told that the Zcorp printers did not play nice with Windows 10. I only used Windows 7 Professional for all of my CNC machines so I never had a problem. I would try connecting the CAT5 cable directly to your router to remove any possibility that, that is causing a communications problem. No LEDs on the CAT 5 connection is not a good sign. I can check my screen shots I took months ago and see what I can find. Also I have a video I could post, Somewhere? so you can see my printer booting up as far as I ever got it to.Cismontguy
01-20-2021, 03:25 PM #12
- Jan 2021
- 6
I'm actually using windows 10 but it was working fine before -Maybe some updates came recently changed that tho-. I tried connecting the printer to the wall ethernet outlet directly, LEDs didn't work too, with a Hub between the computer and the printer didn't light up, either on the hub or the CPU's back. tried other cables, nothing new. I just tried resetting the BIOS but still nothing new.I really appreciate you taking the time to help.
01-20-2021, 03:32 PM #13
- Jul 2020
- 11
No worries. Are you here in the US? If yes, I am on the east coast so about to call it a day. Cismintguy
01-20-2021, 03:45 PM #14
- Jan 2021
- 6
Same, I'm EST time zone. No worries take your time and let me know if you could find anything.Thanks,Mo Abdalla
01-21-2021, 08:43 AM #15
- Jul 2020
- 11
Here is a picture of my Bios as I found my printer, when I got it. In the BIOS the "Onboard Lan Boot" was disabled. No idea why. I changed this setting and saved the BIOS. I connected my cat5 directly to my router and then with the ZCorp printing software open on my computer, I was able to see the printer and use the software set up to make it my default printer.
11-16-2021, 06:06 PM #16
- Nov 2021
ZPrinter 450 Software and drivers
Hi, I bought a ZPrinter 450 on a auction but cant find Zprint to download on much info online. Any Advice on what software and drivers that work with this printer and on Windows 10?
Resin has changed after...
