Results 61 to 70 of 126
Thread: Z axis calibration idea
05-19-2014, 02:14 PM #61
- May 2014
- Troy, NY
- 12
05-19-2014, 02:15 PM #62
- Mar 2014
- 94
I think the main problem with a jewelry scale is that they generally can't hold much mass (at least the cheaper ones). For example if you had a 1 kg max scale the build volume would be significantly less than 10x10x10 cm. Also the container would need to have totally vertical walls. If it doesn't then things could get way more complicated.
05-19-2014, 02:15 PM #63
- May 2014
- Troy, NY
- 12
05-19-2014, 02:16 PM #64
- May 2014
- Troy, NY
- 12
05-19-2014, 02:20 PM #65
- Mar 2014
- 94
Why would it not be accurate? Calipers have extremely good accuracy. I saw on ebay one for only 9 dollars that had 0.02mm accuracy. The one posted was cheaper and had 0.1mm accuracy. Resistors will not achieve that. Plus calipers are much more reliable than using resistance.
05-19-2014, 02:21 PM #66
- Dec 2013
- Georgia
- 934
Now that's actually a pretty great idea. In fact, if you use equal-sized containers for both the top and bottom, then you can use almost all of the ideas in this thread to find the height without any chance of the mechanism coming in contact with the resin. It would also help with the problem of the optical mouse and digital caliper ideas accidentally registering ripples as layer movement.
05-19-2014, 02:26 PM #67
- Mar 2014
- 94
05-19-2014, 02:36 PM #68
There are a lot of different jewlery scales at aliexpress.com.
05-19-2014, 02:39 PM #69
- Mar 2014
- 94
Maybe a scale with less accuracy (like one gram) could hold more. This would still be real accurate and would be simple.
05-19-2014, 03:07 PM #70
- Mar 2014
- 94
For example if the container was just 10 x 10 cm wide then 1 g (~1 cm^3 of the salt water) would add just .1 mm of height. If the container is wider then the accuracy will be even greater. That's like the caliper. The scale has to fit the size of the container which is a drawback since the scale will have to connect to the microcontroller. Work will have to be done to get each different scale size to communicate with the microcontroller properly.
Of course with the caliper it is limited in height (maybe 150 mm), but the other two dimensions could be unlimited in size.
