09-01-2021, 02:41 PM #1
- Sep 2021
Monoprice Select Mini not detected
Hi ,
I am having problems connecting my 4 year old printer to a Windows 10 laptop. It was actually working, until a few days ago. The computer is picking up the USB connection, but doesn't recognise the printer. I have tried different versions of Cura (15.04.2) and also Repetier.
I get this error message when I try to connect :
"Changing monitoring state from 'Offline' to 'Opening serial port'
Connecting to: COM3 with baudrate: 115200 (configured)
Unexpected error while connecting to serial port: COM3 SerialException: 'could not open port COM3: [Error 5] Access is denied.' @ machineCom.py:_monitor:332
Found no ports to try for auto detection
Changing monitoring state from 'Opening serial port' to 'Error: Failed to autodetect serial port.' "
I also tried manually adding the printer to the printer list, but its still not detected.
The other problem is that I can't use an SD card. The card loads to 99% - then stops and won't print, I've tried several different SD cards.
Thanks in advance.
09-10-2021, 08:08 AM #2
okay have you recent;ly had some windows 'updates' (read: totally unnecessary software changes that are guarenteed to bugger something up).
In which case do a system restore to a date when the printer worked.
and then install WUB - windows update blocker, and switch the microsoft toxic software off !
https://www.sordum.org/9470/windows-...-blocker-v1-6/
If you still have problems after that - get back to me :-)
09-10-2021, 05:52 PM #3
- Sep 2021
