05-13-2021, 08:24 AM #1
- May 2021
Which large format dual extruder printer do you recommend?
Hi,
I'm looking for a large format 400x400x450 or above FDM printer with dual extruders so I can print dissolvable supports.
I really like the look of the Gcreate GMAX 2, but it's really expensive and only available from America, so shipping and support concerns.
There must be something similar cheaper and available to by from a seller in the UK.
Any suggestions would be much appreciated.
Thanks
05-14-2021, 01:11 PM #2
At that print volume - no, there are no cheap idex machines.
And a conventional dual extruder is not something you want to be messing about with on a printbed that size !
What's your actual max budget ?
No point buggering around with 'I only want to spend 50p but i could go to £2000'.
Give us the max you can actually afford and we won't waste time with reco0mmending machines you genuinely can't afford. :-)
05-14-2021, 01:18 PM #3
- May 2021
Thanks for your reply.
My target is £1800, but could make it £2000 at an absolute push.
07-21-2021, 07:19 PM #4
- Jul 2021
- 26
You can look for a raise3d E2, but it is a bit smaller than what you are asking for.
07-21-2021, 07:37 PM #5
Under $1000 USD ..
TRONXY X5SA-500 3D Printer (tronxyonline.com)
07-21-2021, 10:12 PM #6
If you are not afraid of a little work to get to your end result you can get an even bigger build volume. This printer has a build volume of 600mm x 600mm x 600mm..
Tronxy X5SA-600 Large Direct Drive 3D Printer 600*600*600mm – Tronxy 3D Printers Official Store
You can buy that build it and then you can buy the dual filament upgrade kit for the 500 pro here..
Tronxy PRO-2E Upgrade Kits for X5SA-500 PRO to X5SA-500 PRO-2E – Tronxy 3D Printers Official Store
Apply that and then you just have to correct the X and Y dimensions in the printer firmware from 500x500 to 600x600 for X&Y. This path will let you build up to a 2ft cube
