Results 1 to 10 of 49
06-25-2021, 10:28 PM #30
- Sep 2020
- 48
I came across a thread that you started in August of 2020 in the "Tips" section where you were working with the same file(s) that I'm working with for my printer, namely the Robin-nano-config35.txt, and an associated bin file. Could you take a moment to describe what you learned about that? I can edit that txt file, but I'm not sure what to do with it after that. Do you just put it on an SD drive and start up the printer? Does the bin file need to go along? Or does the txt file need to be "compiled" somehow? I'm kind of confused about what those files are and which ones are needed for what. Would you happen to know of a source that kind of connects the dots?
