Results 1 to 10 of 49
06-22-2021, 09:48 PM #13
- Sep 2020
- 48
Hi, back again. Took a few days off for Father's Day.
Yes, the Sapphire Plus has 2 Z-axis motors, and if by "dual endstops", you mean 2 z-axis limit switches, yes, it's got that. But, if you use the 3D Touch that is provided, it plugs into one of the z-axis limit switch spots on the motherboard, and so you can't use both.
I had to make a cable for the 3D Touch because the one provided had the wrong connectors and wasn't long enough. That's done.
There's a Youtube video I'm following right now for the installation and they also said that the setting in the firmware were incorrect. They have a whole 2nd video and converting to Marlin. They also said that some problems went away once Marlin was up and running.
Ron
