Results 1 to 10 of 11
05-30-2021, 09:47 AM #1
- Apr 2021
- 30
info about modding tronxy x5sa pro with direct extruder
Hi, I would like to know if you know any direct extruder mods that don't steal print volume..Can you recommend some links to buy?
05-30-2021, 10:11 AM #2
why would any streal print volume ?
Should be as simple as just dropping the extruder on top.
Can you post pics of the hotend and carriage and the extruder.
Pictures from promotional literature never show the stuff you want to see in any detail :-)
05-30-2021, 10:50 AM #3
- Apr 2021
- 30
i have the tronxy x5sa pro stock... i want to add direct extruder without take any print volume (not even a millimeter ;p) i see many project on thingiverse. what is the best?
05-30-2021, 06:19 PM #4
- Apr 2021
- 186
05-30-2021, 07:59 PM #5
- Apr 2021
- 30
can you recommend some links of some direct extruder that takes up little space?
05-31-2021, 01:53 AM #6
- Apr 2021
- 186
Easiest way to mount a direct extruder so you don't lose any space is to stick the motor and extruder up high, above mounting plate, with a short length of PTFE to get to the hotend.
https://www.thingiverse.com/thing:4216612
The disadvantage is that you can't print too fast, because it's a big lump of extruder mounted high about the carriage.
05-31-2021, 12:24 PM #7
- Apr 2021
- 30
What product is it?Where can i buy it?
06-01-2021, 06:20 AM #8
06-01-2021, 02:17 PM #9
- Apr 2021
- 30
It's the same mod. What have I buy on aliexpress to make this mod?
06-03-2021, 10:07 AM #10
Ah - I didn't read the explanation.
Personally I''d make my own bracket and pretty sure I could get around having to cut anything.
There is ALWAYS another way to do something - and often an easier and simpler one.
But alas - i have no pictures of the existing mounting to work with ;-)
