Results 1 to 8 of 8
Thread: Sapphire Pro Thermistor
05-12-2021, 11:30 AM #1
- Aug 2020
- United Kingdom
- 249
Hi I have posted this in the hardware thread as well but I am losing the will to live with this problem. I have had a Sapphire for about 3 weeks and it has give me intermittent almost from the beginning which I traced to a faulty wire to the Extruder thermistor. I changed it for one I got that looked the same and fitted it but now I don't think I am getting the correct temperatures because now though the front panel display shows the temperature I have set I get missive under extrusion and poor inter layer adhesion. I have checker for blockages in the filament feed. Does anybody know what thermistor is correct and a source for one?Cheers Gambo
05-12-2021, 12:42 PM #2
HT-NTC100K Thermistor
According to this replacement on alixpress: https://www.aliexpress.com/i/4000852409068.html
https://www.amazon.co.uk/Printer-The...&rps=1&sr=8-14
And as usual it's cheaper to buy three than one.
I'm really not sure the chinese actually understand the economy of scale.
The number of times I just want to buy one thing and it works out cheaper to buy 5 is crazy.
0.5mm nozzles a classic example, I wanted 2.
Buying just 2 0.5mms was about £12.
Buying an assortment of nozzle sizes to the tune of 20 nozzles (2 of each size) and some other random bits and peices - was £2 cheaper.
Utterly mental.
Same with heatblocks. Wanted one heatblock.
Ended up with 5 blocks, 5 metal threaded throats and another 20 bloody nozzles and some random bits of tubing that always seem to be thrown into the packets.
Also - going back to the actual topic: this is what it says in the configuration file:
#1: 100k thermistor£»-3 : thermocouple with MAX31855
I'll buy a spare off you - already buggered up an endstop when i modded the extruder.
Spares are never wasted lolLast edited by curious aardvark; 05-12-2021 at 01:03 PM.
05-14-2021, 06:40 AM #3
- Aug 2020
- United Kingdom
- 249
Yup CA you are right as usual
05-26-2021, 09:06 AM #4
- Aug 2020
- United Kingdom
- 249
Latest on my Sapphire plus. I obtained a replacement thermistor thanks to CA's sleuthing which solved my problems but unfortunately I had in the meantime I had corrupted my copy of Cura config file so it was massively under extruding which caused more problems. Once that was put right at last Saffy is performing well.
I still have an intermittent problem but have I think located it and will fix it next time I dismantle the extruder !! Now thinking about converting to direct drive extrusion to reduce string and blobbing on some of the odd materials I use.
So all I hope is well I originally said I wanted a tool not a project - but I got a project!! now I have brilliant tool I can now print reliably in polyacetal which had completely defeated me before.
So one happy Bunny (for now).
05-26-2021, 03:46 PM #5
- Apr 2021
- 186
Polyacetal? As in Pom/Delrin? Definitely write up how you go. Very interested.
05-28-2021, 08:59 AM #6
- Aug 2020
- United Kingdom
- 249
Hi Martin_au
Yes polyacetal most commonly called Delrin ( actually a trade name for one version ) is POM Poly Oxy Methylene I struggled with it a year ago and failed in a big way to get to work within the capability of an Ender 3 pro mostly bed temperature, I will start a nother thread if you think it useful go into the full and gory details.
05-28-2021, 09:10 AM #7
we do get a few regular enquiries about printing pom - so yes, any information you can give would be helpful :-)
05-28-2021, 09:36 AM #8
- Aug 2020
- United Kingdom
- 249
In that case I'll start a new thread in the next few days with all I know should fill about 1/2 an inch
